Hikvision software update??
David2749
I have a DS-7204HQI-F1/N DVR, and I've been told I need to update the firmware. I've searched the web to find my DVR model, but cant locate this model.
CAn you please help.
Also, my DVR is in the loft, once and if I can find an update, how do I update my DVR, I only use IVMS 4200 Client software to view my DVR.
Your firmware can be downloaded from here:
DOWNLOAD EU PORTAL
The notes say:
V3.4.0 build151201 for DS-7104(08) 7204(08) HQHI-F_N
V3.4.1 build151221 for HGHI-E HGHI-F
V3.4.1 build160115 for HGHI-E HGHI-F
V3.4.1 build160422 for HGHI-E HGHI-F
V3.4.2 build160119 for 7104(08)_7200HQHI-F_N
V3.4.3 build160203 for 7204(08)HUHI-F_N
V3.4.4 Build160405 for 71_72HQHI-F_N 7204(08)HUHI-F_N
V3.4.4 Build160511 for 71_72HQHI-F_N 73_8104(08)(16)HQHI-F_N 7204(08)HUHI-F_N
V3.4.50 Build160516 for 7200HUHI-F_N
V3.4.51 Build160607 for 7200HUHI-F_N 7600HUHI-F_N
V3.4.60 build160607 for 73_81_9000HUHI-F_N
V3.4.70_Build160708 for 71_72HQHI-Fx/N, 71_72HGHI-Fx
V3.4.70_Build160729 for 71_72HQHI-Fx/N, 71_72HGHI-Fx
V3.4.75_Build160827 for HQHI-Fx/N, 71_72HGHI-Fx, 72HUHI-Fx/N
V3.4.76_Build160914 for HQHI-Fx/N, 71_72HGHI-Fx, 72HUHI-Fx/N
V3.4.80_Build161217 for all turbo 3.0 DVR,
V3.4.81_Build170227 for all turbo 3.0 DVR,
V3.4.82_Build170427 for all turbo 3.0 DVR,
V3.4.83_Build170526 for all turbo 3.0 DVR,
V3.4.84_Build170626 for all turbo 3.0 DVR,
V3.4.87 build180108 for all turbo 3.0 DVR,
V3.4.88 build 180207for all turbo 3.0 DVR,
V3.4.89 build 180906(For HGHI-F)
v3.4.90_Build170205 for 72HUHI-Fx/S
v3.4.91_Build170405 for 72HUHI-Fx/S
v3.4.92_Build170809 for 72HUHI-Fx/S
Our guide to updating Hikvision firmware is here:
How to update HikVision Firmware in just nine simple steps - updated 30th October 2018
I presume this V3.4.2 build160119 for 7104(08)_7200HQHI-F_N is the software I need?????
I am a complete novice here.
I copied this to my desktop.
What do I do next?
I only have IVMS - 4200 client software installed on my pc, as my DVR is in the loft.
Many thanks
It is simplest to complete the firmware update if you use the Internet Explorer browser on your PC, and follow the steps in the updating guide I linked to above.
If you don't know the IP address of your NVR, then install Hikvision's SADP utility and run that first:
DOWNLOAD EU PORTAL
It is simplest to complete the firmware update if you use the Internet Explorer browser on your PC, and follow the steps in the updating guide I linked to above. If you don't know the IP address of your NVR, then install Hikvision's SADP utility and run that first: DOWNLOAD EU PORTAL
I carried out exactly as per instructions, the DVR went through the process of installing the new firmware, but...
After it installed this new build the DVR now doesn't work, no video at all.
Is it still online?
Can you login to the Config area?
What firmware version does it now show?
Is it just video that you are not seeing?
You are not seeing video when you login from IE11 browser?
