At some point yesterday my AX Pro threw up an error on the panel but I can't work out what is causing it. It doesn't clear with a restart, and all it says when it reboots is that there's a panel error. In the panel fault check settings I have Battery Lost, Low Battery, Wifi Lost and Panel Mains Power Lost enabled. Ethernet Lost and Cellular Lost are not enabled as neither are in use and haven't been since I installed it.
I tried turning off all the checks last night, which cleared the fault, and turned them back on individually, with no errors. At some point since I did that this morning the error has come back on again. There's nothing in the notifications either to give me an idea what it is as the last notification was the alarm turning itself off this morning.
I did notice last night that there was an error for 'SIM Card removed' in the notifications but a) it's never had one in and b) as above, cellular fault checking is turned off for that reason. There's been a few errors about that and cellular lost, but again, it's never been used and has never thrown up an error before.
Am I missing something to check to tell me explicitly what the issue is? Has something broken in the panel so it's now throwing an error when it hasn't before? Any ideas, anyone?
