Cable exits from drywall
Stereo_rob
Hi guys and girls, does anyone know a wall plate which accepts multiple inputs/outputs for RJ45 connections. I will have 4 camera cables coming down behind a drywall with plugs on the end and want them exit neatly, like a plug and play setup.
Many thanks
Google around the term 'RJ45 keystone'.
I think that is what you are looking for.
You'd terminate the cable into the back of a keystone module.
I think you would need to cut the RJ45 plugs off and use a punch-down tool to connect your network cables to the keystone modules.
You can get double socket plates that will take four keystone modules.
There may be a complexity in that if you have patch leads installed, those may use stranded whilst the punch-down expects solid cores.
If you'd prefer to leave the plugs on, then just search for brush strip socket plates ...
