Focster
- 4
- 1
Hi.
I have a camera, the model I have specified in the title. This camera is not detected in SADP.
The firmware version is V.5.5.5_180111 on the sticker on the camera body.
I have connected to the camera using UART. And I see that the bootloader version is 3.1.6-269644.
U-Boot 3.1.6-269644 (Jul 6 2017-10:47:55)
boards:296717
Boot From: NAND 2048 RC
SYS_CONFIG: 0x3006005B POC: 101
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model
S-2CD2442FWD-IW
HKVS # help
The following commands are supported:
boot erase help reset
setenv printenv saveenv updateb
upf update format go
mii gpio ping
Using the update command I updated the firmware to IPC_R6_EN_STD_5.5.82_190909.
I got a message that the update was successful... After that I rebooted the camera...
In the UART log I can see how the firmware starts loading... it reaches some point and the camera reboots (it can be seen in the loading log).
How can I fix this? What could be the problem? I have tried different firmware versions for the R6 series, but it doesn't work.
When I try to update via upf I get
boards:296717
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model
HKVS # help
mii gpio ping
