Door Entry Can I connect Villa Door station to PoE in my NVR?
Donvito7
As in ther subject line I have NVR DS-7608NI-K2 and Villa Door DS-KV6113-WPE1(C). Can I connect it vis PoE to my NVR or it shoud go via PoE switch?
Also, can I record the DoorBell view on my NVR?
It must connect to your network via PoE and not the NVR PoE ports. You can then just edit an unused PoE channel as described in your other post.
Did it worked? I have the same problem.
I have connected the Doorbell to the NVR directly and it doesn't work
As I’ve said in post 2 it won’t work. The PoE ports are on a separate network to the LAN. The doorbell cannot communicate with the Hik-Connect server in this case,
