I was thinking about potential emergency measures that might have to be taken in the case of vandalism, where paint gets on the camera (spray/enamel paint, not just latex paint). I could have several potential paint removers ready, but I think most of them might damage plastic. Are these camera lenses usually glass, or plastic? I believe there's also probably an outer plastic window on most cameras, so that most likely would get damaged by the paint remover chemicals.
As an alternative to chemicals, what about a power washer? Is that capable of removing spray paint without damaging a camera? What sort of PSI would be used for that purpose? I know you can cut steel with high enough PSI so obviously, there's a "Goldilocks Zone" for this sort of thing.
