DS-KV6113 and security
antony23
Hi, in the DS-KV6113, there's a hole on the bottom of the device where the network cable and relay wires can get caught without remove the device. This is the first time I've seen something like this; an intruder could access the relay cables and open the door. Have you noticed this? Is there something that i could do?
Well, i would suggest a security module
Then you cant short to open, as only wires outsides will be rs485, while from inside your module trigger door open.
Any difference with DS-K2M061 or DS-K2M062? I checked them and cannot see any important difference.
