Help me setup HikVision DVR to be remote viewed on any browser, hik connect app already works
Hikremotepchow
This link has all screenshots of all current settings of the DVR and Router.
So far have used no ip to setup hostname ddns. And set it up in DVR config page as well. But still no idea why when go from different network to ip to login to config page it will not connect only connects in LAN.
Also know idea how or why but no ip shows ip as 175.157.9.107 when made the hostname and now have changed it to 192.168.8.100 thinking it maybe wrong?
Please advice what is wrong in my settings by viewing all ss I have attached
Firstly, your sharing a lot of personal info, like email addresses, domain names etc. Be careful
You have DDNS added in your router so that would update NOIP domain name. But then you also have set it up on DVR which from your images appears to update different domain name to the one the router would update. Personally I would just use the one that router is updating with your real ip address.
You should only need to forward ports for server port and RTSP. So, what ever port you want to use externally mapped to the internal port of DVR.
Access remotely would be domain name e.g blahblah.blah:external server port number
For accessing web admin, I would not forward that but instead use VPN in and then local ip address.
Could you give me a step by step instruction for example like; go to Router sign in page go to port forwarding tab then change ip to 175.157.9.107 or whatever else is correct ip
