D dba7108 Member Messages 6 Points 1 Aug 24, 2024 #1 I can't find a bracket for this camera. I'm after a junction type back or an L shape bracket. What model bracket do I need and where can I buy it?
Solution Dan Aug 27, 2024 Hi @dba7108 The compatible accessories for this PTZ are the DS-1280ZJ-SD11 Junction Box and the DS-1605ZJ Wall Mount. If you want to wall mount your PTZ, you only need to buy the DS-1605ZJ Wall mount because the camera mounts directly to the wall bracket.
Dan Administrator Staff member Messages 4,474 Points 113 Aug 27, 2024 #2 Hi @dba7108 The compatible accessories for this PTZ are the DS-1280ZJ-SD11 Junction Box and the DS-1605ZJ Wall Mount. If you want to wall mount your PTZ, you only need to buy the DS-1605ZJ Wall mount because the camera mounts directly to the wall bracket. Upvote 1 Solution
