HiLook CCTV
Pablo56
Hi. I know that this is a lower end CCTV, but I am a home user on a tight budget. There are some issues which you might know about.
1) I set the time on the system (currently: 17:50). I have only 1 camera attached and on a PC monitor it displays 18:50. The time on the camera is 1 hour more. This can't be right. It would not stand up in a court of law.
2) I have tried to set some small recording skedules each over a period of 5 minutes. Should I not see a list of recordings when I go into admin? When I click on rexordings, I see a time line under the camera on the bottom of the monitor with a few red markers along the time line.
I will contact rthem tommorow about this but I would like to here from you guys first.
Hi @Pablo56
Are you able to confirm the exact HiLook recorder and camera models you have?
Is the camera plugged directly into the ports on the recorder?
Can you share screenshots of your record schedule and playback timeline as we are struggling to understand what you are describing?
