Integration of an axis P3713-PLE multi-sensor camera's quad view on my Hikvision NVR?
JulioFr1ch
Hello everyone, I recently acquired an axis P3713-PLE multi-sensor camera and I added it to my Hikvision NVR without problem using the AXIS protocol, but I would like to add the Quad view to the NVR because currently I do not see that only one stream out of the 4 that the camera has can you help me?
Hi @JulioFr1ch
I think from our past experience, the Hikvision NVRs will not support quad-view for 3rd-party multi-sensor cameras and it doesn't make a difference if they are added via ONVIF or a brand protocol.
yes indeed maybe via the rtsp stream but then I have to dissociate the camera from the nvr because if I add it via the nvr it doesn't work because it has the same IP address
