Is more channel better?
junkymail00w0
I assume nvr with more channel is more powerful than that with less channel? If so, should I buy a 16 or 32 channel nvr for upto 8 cams for my house? My house will definitely use no more than 8 in forseeable future.
Hi @junkymail00w0
It depends which manufacturer you are looking at, but the 16 channel will normally be more than powerful enough, but probably still overkill for 8 cameras.
This Hikvison 8 Channel NVR is the most popular model that we sell and allows you to fill it completely with high resolution (8MP/12MP) cameras, without any issues - Hikvision DS-7608NI-I2-8P 8 Channel Network Video Recorder
The best way to check is to look for the "incoming bandwidth" budget for the NVR against the maximum bandwidth used for each camera, and make sure the total is within that budget - you'll be able to find all of this information in their datasheets.
