Issues After Updating to the Latest firmware for the DS-7104NI-Q1 NVR
jf_moreira
Hello, everyone.
This is my first post here, after being reading and learning from other posts in the last months.
I have a DS-7104NI-Q1 NVR and despite it being super easy to install the cameras, for changing configuration it has been not so much.
I recently updated it, following Hikvision support suggestion to the 220919 build as show below in the screenshot after this post.
The problem is that now I lost the few capabilities I had for changing cam configuration. Before the update I was able to go into iVMS (Maintenance > Group ) click in the gear icon and was able to at least change the bitrate. After the update if I click in the gear icon for every camera the menu is reduced and I can only edit the NVR configuration. I can't see any options for changing config via Web too.
Also, I could not find any Virtual Host options for this NVR (network > advanced > other).
Can anyone shed some light over accessing cam configuration in this NVR without having to resort to install another POE switch?
What if I tell you that I had another hikvision DVR with a POE switch and decided to upgrade to this NVR to get rid of the extra POE switch... :/
