- 5,170
- 113
I'm interested in a dome IP camera with SD card. Couple of questions please :
Perhaps take a look at the HikVision 2632 bullet or 2732 dome cameras.
Answers to the above:
1. Yes, you can set it to continually record to the card and just overwrite the oldest data.
2. It depends on the settings you use and the capacity of the memory card:
1080p resolution / 3fps / h.264 = just under 7 days of continuous recording to a 64GB micro-SD card
3. You should be able to do so (access and review/playback) from your browser (we haven't got a Mac to be sure)
- Can it record continually to the SD card and if so when the card is full does it stop recording to the card or does it overwrite, erasing the oldest images first?
- How long would it take to fill up the SD card in continuous mode.
- I do not want to hook the camera up to an external recoding device I just wish to interrogate the SD card whenever I feel it necessary - is this possible to interrogate the SD card from a mac without removing the SD card and plugging the SD card into the mac?
