P prop Well-Known Member Messages 88 Points 8 Feb 17, 2024 #1 i have 2 different dvr systems that i would like to view at once. is that possible?
D David Guru Trusted Member Messages 1,220 Points 83 Feb 18, 2024 #2 prop said: i have 2 different dvr systems that i would like to view at once. is that possible? Click to expand... Should be possible, how do you remotely access them at the moment? David
D David Guru Trusted Member Messages 1,220 Points 83 Feb 19, 2024 #4 prop said: laptops , cellphone Click to expand... What software / app do you use to remotely access the DVR's? I use a VPN to connect to my home network, then I can monitor both NVR's at the same time. It should be possible to do the same using port forwarding, this is not very secure. David
P prop Well-Known Member Messages 88 Points 8 Feb 19, 2024 Thread starter #5 i am using optiview and hik-vision software
