What would be a suitable POC camera for use with DS-7204HUHI DVR?
sid_
Can anyone advise on this. The CCTV system in our new home has 3 cameras installed at roof level and I would like to add a 4th. I don't know the models of the existing cameras and I suspect that a lot of modern ones will not be suitable for the older DVR.
Either fixed or pan and tilt POC camera.
Any PoC model 5 megapixel or less will work (that assumes your DVR is a DS-7204HUHI/P as the 7204 is available with or without PoC) . You can also use the newer 3K resolution models. If you do choose a 3K model, you will need to patch the firmware on your DVR before installing the camera, as otherwise it will not work.
