fahadabrar
- Messages
- 1
- Points
- 1
Dear all
I have an interesting problem to solve.
There are two separate physical locations; at one location there are two Hikvision cameras on a network (not hooked up to an NVR). I want to add these cameras over the internet from the first location to another location with a Hikvision NVR.
I have set the server ports on camera 1 and camera 2 to 8001 and 8002 respectively.
My router port forwarding rules look like this
Rule 1
External port: 8001
Internal port: 8001
Device IP address: First camera's internal IP address
Rule 2
External port: 8002
Internal port: 8002
Device IP address: Second camera's internal IP address
Rule 3
External port: 554
Internal port: 554
Rule 4
External port: 554
Internal port: 554
I add the cameras to the NVR at the second location using the external (public) IP for the first site and respective ports (8001 & 8002) for each IP camera with the correct user and password, but interestingly on the screen I see the same camera video stream repeated twice (i.e. I see camera 1 twice on the screen)
Why so?
What should my port forwarding rules look like?
The issue we have that I am thinking is that the Hikvision NVR code is hardcoded to look for the video stream on RTSP port 554 and I have no way of changing that on the NVR if you are familiar with the camera adding screen on Hik NVRs.
Any bright ideas anyone?
Thank you in advance
Rule 1
External port: 8001
Internal port: 8001
Rule 2
External port: 8002
Internal port: 8002
Rule 3
External port: 554
Internal port: 554
Rule 4
External port: 554
Internal port: 554
Why so?
