DS-7608NI-I2 / 8P going off line?
rosswill
Hello I have a DS-7608NI-I2 / 8P with 7 cameras connected directly to it. Everything runs and does what I expect for around 2 weeks when I notice I can no longer log in with the Hikvision app - cameras offline message is displayed. If I log in from the local network I can see from the logs that the NVR effectively stops reporting events after a period. A simple remote reboot of the NVR brings everything back online and it will all work again for a while until things stop and the whole thing is repeated.
First question is what can I do to fix this. Do I need to replace the NVR for a more recent model? If this was the fix how easy would it be to transfer settings across from the old device?
Thank you
Ross
Hi @rosswill
Can you please confirm the firmware version that your NVR is currently using?
Hello it’s the latest firmware I’m away from the device currently but when I checked last night it was the most recent
Okay,
When you can, please confirm the version your NVR is running because sometimes people think they are running the latest when they actually aren't.
Can you please also confirm the camera models you have connected to the NVR and the firmware versions they are running?
NVR V4.61.025 build 220905
DS-2CD2086G2-IU V5.7.3 build 220112
DS-2CD2086G2-I V5.5.801 build 211105
DS-2CD2183G2-IU V5.7.3 build 220112
Regards Ross
Thank you I have updated firmware this evening and will see if this helps
