DS-7608NI-K1 / 8P - Firmware Upgrade
BerkoJas
Hopefully someone has recently upgraded their firmware for a DS-7608NI-K1 / 8P ( date 01/2022 ) NVR
Currently I am on, Firmware V4.32.115 build 211129 but have been told that a newer version is available which is V4.71.000 build220224
Looking around I found this under
this lists two sub versions NEU & STD, any ideas what the difference is?
Also I've read that you should apply firmware upgrades in order not missing any intermediate versions, the previous version on for the website for the above is V4.32.110 Build211009 whilst i have version installed V4.32.115 build 211129 which is not even listed as existing, which makes me think i may be in the wrong download section entirely!
Any advice appreciated.
I think i found more firmware versions for DS-7608NI-K1 / 8P here ( it's a bit of a crystal maze ! ) :
So would advice be install V4.32.116 before V4.71 ??
Hi @BerkoJas
Hikvision firmware can be a bit of a minefield.
It looks like the version you are currently running is a UK firmware so we would recommend that you update to v4.71.000 from the UK Download Portal
