Firmware Finding the latest firmware for my Hikvision cameras?
Gwladok
Hi!
Is it possible for someone to let me have a link to upgrading the firmware on my 2CD2385FWD-1 & 2CD2385G1-1 cameras?
Hi!
D1DS-2CD2385FWD-IV5.4.5 build 170124--Latest Version Already --
D2DS-2CD2142FWD-IV5.5.82 build 190909--Latest Version Already --
D3DS-2CD2142FWD-IV5.5.82 build 190909--Latest Version Already --
D4DS-2CD2385G1-IV5.6.5 build 200316--Latest Version Already --
D5DS-2CD2142FWD-IV5.5.82 build 190909--Latest Version Already --
D6DS-2CD2385G1-IV5.6.5 build 200316--Latest Version Already --
D7DS-2CD2142FWD-IV5.5.82 build 190909--Latest Version Already --
Sorry! I thought it might be useful to add all of my cameras to check for updates!!
The DS-2CD2385G1-I and DS-2CD2385FWD-I both use the same firmware, please find the link below...
The DS-2CD2385G1-I should be fine to upgrade to the latest firmware version (V5.6.820 220519).
As the DS-2CD2385FWD-I is a bit more out of date, we would recommend upgrading to V5.5.80 180911, then to V5.6.1 190604, before then upgrading to the latest firmware version (V5.6.820 220519).
The DS-2CD2142FWD-I's seem to be on the latest firmware version, you can always check by going to this link below...
Most grateful Jake
One of my DS-2CD2142FWD-I needs replacing.
What is the straight swop equivalent product as the 2142 is obsolete?
Most grateful Jake
Jake, I can't undate the 2385FWD as it keeps asking me for the plugin which I have run.
Any ideas??
It may be better to try viewing the cameras using Hikvision's iVMS-4200 software instead.
The download link for iVMS-4200 is below...
Jake
I am grateful for your patience!
I can't get my head around iVMS-4200
I then realised that I can upgrade the cameras via a usb stick.
However, when I go into the local upgrade, the USB stick is showing but when I click on DAV, ZIP file type, the upgrade file does not come up!!
I thought I was nearly there.
I have tried adding both the zipped download & the unzipped DAV file to the stick but neither are recognised.
Just a wild guess...... what are the chances your USB stick is formatted as NTFS or exFat ?
If so, you might have better luck re-formatting it to FAT16 (or FAT32).
