What is the maximum resolution that I can record on each channel of my DS-7604NI-SE-P NVR ?
Oovarvoo
I have a Hikvision DS-7604NI-SE-P and some 4 x DS-2CD2122F-I cameras, I am not very knowledgeable in all this so I need to know firstly, What is the maximum resolution that I can record on each channel of this NVR ? and also I am possibly thinking of upgrading the cameras if possible so what would anyone recomend?
Both your NVR and cameras are quite old and have been end of life for some time. The 7604NI-SE-P can take cameras up to 5MP resolution. Both the cameras and NVR only support H264 encoding.
I'd probably recommend updating the NVR before the cameras. Swapping it out for a 7604NXI-K1/4P would be the logical replacement. That model:
  • supports H265 encoding which is more efficient on disk space (once cameras are updated as they also need to support H265).
  • accepts 4 x 4MP cameras
  • supports Hik-Connect app and service (your existing NVR only supports the old HiDDNS service which is no longer available)
  • has AcuSense which will allow you filter motion detection events to Human for fewer false alerts
  • as an up to date model it's still receiving firmware updates so in the event of s security issue can be patched (there's a very good chance your cameras are on old firmware and will be accessible using 'admin' and 12345 as the password)
Once the recorder is replaced you could replace cameras as you like. I'd recommend the DS-2CD2347G2H-LIU:
  • Turret format - won't collect rain residue like your current domes
  • 4MP
  • large 1/1.8" sensor - ultra low light
  • Hybrid infra red and white LED illumination - can be set to normal colour/mono, 24/7 colour or smart (colour/mono but switches back to colour in darkness when an event is detected)
  • AcuSense false alarm filtering. While it's available on the NVR detailed above, using it on the camera (where available) provides better results.
  • 4MP
Thank you so much for your reply, I knew it was old stuff and I will have to make do for now until I find something suitable. Can I just ask, on my current NVR what is the maximum resolution that I can record upto on each channel with my current cameras and if I had better resolution cameras what would be the maximum then?
The NVR will take up to four 5 megapixel cameras. Your cameras are 2 megapixel models so a max of 1920 x 1080
So that's 1920 x 1080 for each of the 4 channels?
Sorry, as I said I'm not very knowledgeable on this stuff.
