Multiple DS-2CD6825G0/C-IS People Counting Cam Network Install?
Tailhook
Hi, I've three Hikvision DS-2CD6825G0/C-IS people counting cameras to install in a single site. In terms of network config, my plan was to set for DHCP and Hik-Connect, no uPnP, etc. That all being the case, should this multi-cam setup work, out of the box in this config? Thanks in advance.
Hi @Tailhook
Yes, there shouldn't be any problems having 3 x people counting cameras on the same network and adding them to Hik-Connect.
If you do use DHCP to find available IP addresses for each camera, make sure to disable DHCP once an address has been assigned to a specific camera to keep that camera fixed to that IP address.
