I have an issue with my hikvision door entry... It works as it should connected to the PoE switch via a short ethernet cable. When I connect it to the LAN cable next to the door it gets power but no network, it does this on 2 other LAN cables around the house. I've connected a laptop at each point and get an internet connection to check.. I also connected a drum of cable to th switch and it works fine off that, so I am a little bit lost as to what the issue is
