Hi everyone,
I have a DS-7604NI-K1/4P (not the B version) NVR. It's been working flawlessly for 1.5 years, with the same HDD. But a few weeks ago it started to randomly beep (5 beeps) and the HDD seemed to be constantly powering up/down. No indication in the Hikvision logs as to what the cause could be.
Of course, I assumed it was a failing HDD. So I tested it extensively with SeaTools (it's a Seagate Skyhawk 6TB), and everything came back clean, except for the SCT Same Write Erase, which fails. But this seems to be a problem with the test perhaps: Seagate 3TB Hard Drive Woes).
I contacted the supplier of the NVR and got some newish firmware, which I loaded, but the same problem reappeared. I then tried a different smaller SATA drive which I had lying around (500 GB) and it's been working perfectly (no beeps).
I'm still not entirely sure if this is the NVR losing the ability to power a modern drive (capacitors?) over time, or this is the actual drive itself. I thought the Seagate surveillance drives were pretty good at constant writes from NVRs, and indeed, the drive itself does seem fine.
Any advice?
John
Any advice?
John
