Hikvision camera picture download Windows ISAPI utility... downloads pictures from SD card ready for timelapse
johnfitzy
Knows a LOT of stuff
howdy... I created this utility program using Visual Studio... it downloads .jpg pictures from the SD card in Hikvision cameras... it's helpful if the camera is not easy to reach to remove the card... if anyone is interested in trying it, I have attached a zipped-up file...
PLEASE USE LATEST VERSION AT END OF THREAD!
howdy... someone reported a connection timeout problem when downloading over a slower Wi-Fi network... I had the http requests set to timeout in 1 second (for no good reason) ... I have changed the timeout to 15 seconds... I have also changed the way GMT/UTC hours offset defaults, so it accounts correctly for daylight savings time... V1.1 is attached here...
one more small change to timeouts... V1.2 attached...
last change to timeouts... added 30 second timeout to wait if a Wi-Fi network disconnects... V1.3 attached...
Thank you for a great tool. Is it possible to have you to make the source code for the tool avaliable here, or to send it to me?
