ANPR not saving images to NVR
kmb786
Centurion!
Hi All,
This is my first time on this forum as I have recently had Hikvision cctv installed and currently have the following issue which I hope someone on here can advise before I go back to the installer which could be after the Christmas break.
I have a NVR model DS-7604NI-K1 / 4P(B) - firmware V4.30.010 build 200715 which I believe is the latest version.
I have one bullet camera model DS-2CD2685G0-IZS - firmware V5.6.2 build 190701 connected to the NVR
I also have an ANPR camera connected to the other side model DS-2CD7A26G0/P-IZS - firmware V5.6.10 build 200703
The ANPR is correctly configured and working and is capturing the number plate registrations as it is listed when I go to the camera web browser and click on the Configuration --> Road Traffic --> Real-time LPR Result and the max. 20 records are listed.
My issue is that the NVR is the saving the number plate images to the NVR as if I go to Picture --> Search then it says no pictures found.
I have been reading on this forum and looking at Youtube videos, and what I have noticed is that if I log on to the NVR web browser and go to the Configuration tab, and underneath there, I cannot see the sub heading "Vehicle Detection" which I'm assuming is where I configure the vehicle detection information similar to like I did directly on the ANPR web config.
The forum tutorials I have seen on here and the youtube show this option on the NVR.
Therefore, can someone please help as is this a firmware/software issue and/or are the above devices compatible with each other as this system was installed by ADT so I cant really see there would be any compatibility issue.
Thank you.
You’ve got a “k” series 7704NI-“K”.... I’m 99% sure the “I” series is the lowest spec for ANPR compatibility so 7708NI-“I”.... for example, it’s the model up from the “K” series.
Hi fin Thanks for your reply. So are you saying that the DS-7604NI-K1 / B) version I have is probably not compatible with the Anpr camera I have?
Are you recommending I get the DS-7708NI-I?
if the above is the case then I don’t understand why the installer did not know about this as they’re quite a well known and big company.
I have also emailed Hikvision Support so I will also see what they say.
Thank you.
Bump - I’ve had no official reply so far from Hikvision Support so just wandering anyone else on here can confirm that the issue is my NVR model.
I am 99.9 sure I am correct and you need an “I” also I understand Hikvision support only responds to dealers not general public
Hi fin
Thanks for your reply again.
When you say the “I” model would
DS-7608NI-I2/8P work with my NVR.​
Well that would replace the whole NVR the one you have listed there is an “I” series the ones that I understand work with ANPR
I had mine running on 7708NI-I4 which main difference is the 4 is how many HDD and more bandwidth, I upgraded that to a 7716NI-I4 as I wanted more cameras running 6x 8mp camera and intercom 6113 and two ANPR cameras all Hikvision
Hi fin
thanks for this. Which one would you recommend as when I return this one to the installed I’m going to ask for a 8 port model for future expansion as I’m now planning to get maybe three colorvu turret cameras which means I will be a port short on the NVR.
If you could give me the exact model number I need if the NVR for a 8 port NVR that will work with my ANPR then that will be most appreciated.
7708NI-I4/8P I’d go for, others may recommended others as there are slightly later versions I believe but I only bought my 7716NI-I4 the other month so still very much for sale and I bought that based on how good the 7708NI-I4 I had was I just wanted more cameras it’s basically the same unit
Thanks fin. I will get back to the installer in the new year and see what they can do.
Hi fin
Sorry to ask again but I think this model will also be ok for my needs as I only have one 3TB purple western digital hdd and also to keep costs down as this should also work with my Anpr.
DS-7608NI-I2/8P​
I’m running the components below and have no problems with the ANPR
DS-7608NI-I2 / 8P with firmware V4.40.016 build 200803
DS-2CD4A26FWD-IZS/P with firmware V5.4.7 build 180309
Thanks for your information.
I am going to ask my installer to change my NVR to the above model as the one that I have captures the plate info but does not actually save the pics to the NVR.
The NVR I have (DS-7604NI-K1 / B) does not have the Vehicle Detection option under Configuration. This is where the problem is I think so now going to ask to change it to DS-7608NI-I2 / 8P.
Hi All,
I've had the DS-7608NI-I2 / 8P and the extra cameras installed and configured yestrday.
The issue with the anpr not saving images/clips of reg plates is now solved so it was definately the DS-7604NI-K1 / B NVR not being compatible with the anpr camera.
Thank you all for the advice.
