Hi all, looking for any potential solution to get one of my cameras detecting motion & intrusion, everything is setup correctly as far as i can see, the camera is a DS-2CD2387G2H-LISU/SL, all detection zones are set, linkage set, but it regularly does not see our car enter the driveway, or people, its intermittent, sometimes it does, then doesn't, it seems to be worse at night.
I have motion currently set on this camera at 100%, intrusion at 100%.
All cameras on H265+
Exposure 1/100
HDR Off
Noise reduction 50
Variable bit rate
video quality medium
20 FPS
Tried adjusting the Min/Max boxes, changed the perimeter to see if this helps.
Camera is set on smart so its black and white until motion is detected, then colour.
24/7 recording.
Checked all settings to ensure all notifications are set correctly.
I have also turned on VCA on the hik-connect app, walked under the camera, intermittent whether it detects or not, 80% it gets people, 10% it gets our car, the red perimeter line does not always change to red to show detection, but the next day it might work correctly.
Camera is about 3m high. no obstructions, clear view down our driveway, angled as its on the side of our house, driveway runs front to back.
Could this be a software/firmware issue as everything i have tried does not seem to make much difference.
NVR: DS-7604NXI-K1/4P Acusense
Exposure 1/100
HDR Off
Noise reduction 50
Variable bit rate
20 FPS
24/7 recording.
| [D1] Front-Cam01 | DS-2CD2387G3-LIS2UY/SL | V5.8.10 build 250605 | -- | The version is already the latest. | -- |
| [D2] Rear-Cam02 | DS-2CD2347G1-LU | V5.6.821 build 230831 | -- | The version is already the latest. | -- |
| [D3] Driveway-Cam03 | DS-2CD2387G2H-LISU/SL | V5.7.19 build 241207 |
