Due to "Device error" when I try to change some of the Smart Event I have been adviced from Hikvision to do a Default. In IVMS-4200 there is two choices: Restore and Default. There is a difference where Restore reset all parameters, except IP parameters and user information, but Default restore all. Further I can read in the manual that in the last choice the ip is set to default and I may need SADP (beeing in the same local network) to change it. That is a problem for me as I am remote 200 miles from the camera. This camera will be given default 192.168.1.64.
I have two questions:
1. As I use an asus router remote with local network 192.168.1.xxx, is it possible for me to only use IVMS-4200 from remote to change the ip after doing the "strong" Default, Default?
2. Is there any other difference between Default Restore and Default Default than the mentioned IP parameters and user information? That is important to me because my "Device error" problem certainly not have anything to do with Ip parameters and user information.
