Enable Virtual Host in NVR 5
Mattycee2K17
I have had a search and keep coming up short and cannot find the settings I need to enable Virtual Host in the settings on the newest NVR 5.0 software.
Is someone able to advise were I can turn that switch on?
via the WEB UI interface on v5.03.010.... navigate here:
Device Access --> Device --> Video Device --> ...more --> Virtual Host Configuration
Solution
Also, you don't actually need to use virtual host any more on the 5.0 firmware - on the Video Device page, you should have an 'Operation' column at the end which has a button allowing you to log in to each camera :)
The advanced image settings, which you used to only be able to access via virtual host, are also now available in the NVR's image settings.
