aliraza11024
- 6
- 1
Hi i need hikvision DS-7208HQHI-K2 FIRMWARE UPDATE
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Ali,Hi i need hikvision DS-7208HQHI-K2 FIRMWARE UPDATE
sir now this firmware version v.35.23build171109Ali,
what is the current firmware version?
David
Hello Ali,sir now this firmware version v.35.23build171109
thank you sirThe latest firmware for your DVR is 4.25.001 build 201107, see the download link (second file). You can upgrade straight to this version but it's recommended you factory default and set your DVR up from scratch after updating
What is the reason for factory default needed after the update?The latest firmware for your DVR is 4.25.001 build 201107, see the download link (second file). You can upgrade straight to this version but it's recommended you factory default and set your DVR up from scratch after updating
It's not necessarily needed. However in the above case, the user was skipping 3 years of updates to the latest. Version 3 to version 4 is a major update so issues can occur.What is the reason for factory default needed after the update?
