R rozi New Member Messages 1 Points 1 Jun 27, 2025 #1 Hi, I have a question. What firmware do you recommend for the panoramic camera Hikvision DS-2CD2387G2P-LSU/SL(4mm)(C) which allows direct youtube streaming via RTMP. Thank you for your help. Petr
Dan Administrator Staff member Messages 4,901 Points 113 Jun 27, 2025 #2 Hi @rozi The newest firmware version to support RTMP would be this one - V5.7.1 But this firmware is for the core range of G2 cameras; the G2P panoramic cameras use slightly different firmware. If the 2387G2P camera won't accept the V5.7.1 firmware, that most likely means that the G2P models won't support RTMP.
trempa92 Knows a LOT of stuff Trusted Member Messages 497 Points 43 Jun 29, 2025 #3 There is newer, but its EU firmware 5.7.13 https://www.hikvisioneurope.com/eu/portal/?dir=portal/Technical%20Materials/00%20%20Network%20Camera/00%20%20Product%20Firmware/Temporary/G5%20Platform%EF%BC%882xxxG2%28C%29%EF%BC%89/RTMP
