Hi there!
I have a very particular issue which may not be possible to fix but its worth a try.
A customer I am doing work for wanted a thermal camera set up to detect if something catches fire in a warehouse.
The camera has been setup and is using an alarm output to send an SMS via a separate device when the thermal camera sees 220+ Degrees C.
This worked flawlessly... But the issue we encounter was that the thermal part of the camera is far too zoomed in so it doesn't see the whole area.
Instantly as a work around I set the camera to scan the area (it's a PTZ) which seemed like it would solve the issue. Wrong.
When the camera is moving its heat detection functions no longer work. No heat is recorded until it stops for 5 seconds.
Has anyone else had an experience in this situation?
Any help is appreciated.
Thanks.
Hikvision DS-2TD4228-10/W
Thanks.
