Hikvision IPCam disconnecting problem
Cray24
I have 8 IP cameras installed in our house and it works very fine in a year, but now I got a problem with one of my camera it keeps on disconnecting every time to server, sometimes it disconnect for about 9 hrs straight and then comes back. There's no particular time of disconnecting. I already change the IP address of the camera, update the firmware, and also check the wiring of it but still the problem persist. Can anyone help me out of this ? Thanks.
Attached photos are the recording of the camera per day.
Check the logs of the camera and NVR to see if there are any clues.
There is an error message stated at the bottom of your screenshots. Unfortunately, although I have an error checking tool from Hikvision it provides little help/advice. I'd recommend that you contact your local Hikvision Tech Support and ask their advice / interpretation of the error message.
If you resolve it, perhaps you'd be kind enough to come back here and share the answer.
