How to get HIGHEST settings on NVR
Ben@Elec-Inn
I have a DS-7608NI-K2/8p
Currently, if I set my 8MP cameras to Highest image quality they do not record or run on live view at any frame rate.
I lower that to the 'Higher' setting then they run even at 20 FPS.
Is there something I should be doing differently?
I'm slowly replacing all my cameras. Eventually I will have 6x 8MP.
What is currently the best NVR for this? Or is it not an NVR issue?
You need to find out the specs on that K model and determine maximum incoming bandwidth. Then calculate the incoming bandwidth of all your cameras. You are likely exceeding it.
Also, make sure you're using the best video compression, H.265+ if possible (if you've not set up any smart events), or H.265 is the best alternative.
