How to set 2 cameras in Besder DVR
kevoldinho
I own Besder Mini DVR (US $26.93 40% OFF|BESDER Mini NVR Full HD 1080P Recorder 4 Channel 8 Channel Security CCTV NVR 1080P 4CH 8CH ONVIF 2.0 For IP Camera System 1080P-in Surveillance Video Recorder from Security & Protection on Aliexpress.com | Alibaba Group), which I used to connect two of these Revotech cameras (Buy Products Online from China Wholesalers at Aliexpress.com). One of the cameras stopped working, therefore I've bought this one from Amazon - SV3C IP Camera (https://www.amazon.co.uk/gp/product/B073GSSGWB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1).
The problem is that when I try to connect them to my NVR, either one of them only will work if I set the right Network settings for them - and my problem is:
How do I set the same gateway, subnet mask dns and port for both of these so if I click search on my dvr both of them will pop up?
The Revotech camera uses these details:
IP Address: 192.168.1.3
Gateway: 192.168.1.1
Subnet Mask: 255.255.255.0
DNS: 192.168.1.1
And the SV3C camera use these details:
Gateway : 192.168.0.1
IP adress: 192.168.0.90
DNS: 192.168.1.1
If you could help me with setting the NVR so both of them will work then I would be really grateful.
Sorry, we have no experience with any of these models.
You will need to get all of the devices set to IP addresses within your home network's domain range.
DNS: 192.168.1.1
DNS: 192.168.1.1
hi kevoldino,
try to changethe subnet mask in the router to.255.255.0.0 Then you can access them andharmonise the io address
