Looking for some insight into an issue at home.
Sometimes when my cameras lose then restore power they come back online using far more recorded bandwidth than normal. Once I've spotted it I can usually restore this by changing and then restoring a camera parameter (say fps) - using web (browser) access from the NVR itself (Configuration/video/Audio-video).
But this is a nuisance, relies on my seeing the effect, uses more recording space thus reduces available history time and shouldn't happen (but I think it always has since set-up here a year or so ago).
Any power outage can cause the effect but I'm unsure that it always does so and I often have problems settling the cameras down to what I consider normal.
The last occasion it was only the cameras on one switch that were affected (due to that switch resetting).
Is it the cameras or the NVR ? Maybe a setting I'm missing on the NVR that says 'reset the cameras like vis' ?
Example settings of #1 below (inc. camera accessible only settings) in case I've got something weird there - other cameras are similar, sometimes a minor shift in frame rate or max bit rates.
Camera [D1] #1 Front
Stream type Main stream (normal) Sub stream Main stream (eventl) Third stream Transcoded stream
Video type Video & Audio Video & Audio Lkd Video & Audio Video (video)
Resolution 3840*2160 640*360 Lkd 3840*2160 1280*720P 704*576
Bitrate Variable Variable Lkd Variable Variable (variable)
Video quality Highest Highest Lkd Highest Medium (highest)
Frame rate (fps) 18 18 18 10 18
Max bitrate (kbps)16384 512 16384 512 512
Video encoding H.265 H.265 Lkd H.265 H.264 (H.264)
H.265+ Off -- -- --
Profile Main profile Main profile Main profile
I frame interval 36 36 50
SVC On Off Off
Smoothing 25 50 50
NVR iDS-7716NXI-I4 / X(B) V4.50.000 build 210125
#1 DS-2CD2186G2-ISU V5.5.820 build 231108
#2 DS-2CD2186G2-ISU V5.5.820 build 231108
#5 DS-2CD2186G2-ISU V5.5.820 build 231108
#6 DS-2CD2186G2-ISU V5.5.820 build 231108
#7 DS-2CD2186G2-ISU V5.5.820 build 231108
Certainly one to ponder.
H.265+ Off -- -- --
SVC On Off Off
Smoothing 25 50 50
