I'm networking my property and installing CCTVs but I need advise and help
- x2 RJ45 ports per room (total 5 bed rooms)
- x1 RJ45 ceiling port per landing for APs (total 3/4)
- Should I consider running CAT6 to my bathrooms/toilets?
As I am running CAT6 to each room, should I split it such that floor1/2 have a 1 comms area and floor 2 has another comms area and I can run 2 CAT6 and Fibre cables between the switches? Also I was thinking to have the NVR in the garage which will also be connected to a network switch - if this is not correct be advise
I will also run CCTV maybe 6/8 in total, I have IP cameras in mind as I will be running CAT6 cable to each camera, also what CCTV camera do you recommend with budget max 1500GBP
The property has bay window like this picture I found on google but my drive way is much bigger - I am considering like this?
