Hi, I'm new to the forum and haven't got a clue what I'm doing so would be grateful for some help.
I've just bought a Hikvision iDS-7204HTHI-M1/S Turbo HD DVR which is Wi-Fi enabled when using a USB Wi-Fi dongle.
My set-up has a TP-Link 4 port POE switch connected to the only available LAN port on the DVR with an 8MP IP camera plugged into the POE switch.
A Wi-Fi dongle is plugged in the rear USB port which works okay (after a few attempts at getting a compatible one)
Everything seemed to configure okay, camera displays okay etc but the problem is that I cannot access the camera with my laptop wirelessly to configure its settings.
FYI, the default DVR IP address is 192.168.1.64, the camera's address was the same and caused an IP conflict so I changed the camera's IP to 192.168.1.65 and it was okay then.
I would like to access scheduled switch which is not available in the settings from the DVR but when typing the camera's IP address into my browser I cannot connect.
The only way I can connect is using an ethernet cable from my laptop to the POE switch and open SADP tool. This shows my DVR and camera. If I double-click on the IP addresses nothing happens unless I let SADP reconfigure the addresses and I end up with 169.254.x.x addresses. Double-click on those and it works but unplug the ethernet cable, type those new addresses into my browser and nothing happens and I have to reconfigure everything again.
My current network settings under TCP/IP are as follows;
LAN1 - IP Address 192.168.1.64 - Subnet Mask 255.255.255.0 - Default Gateway 1.0.0.0 - Preferred DNS Server 194.168.4.100 - Alternate DNS Server 194.168.8.100
WLAN0 - IP Address 192.168.0.119 - Subnet Mask 255.255.255.0 - Default Gateway 192.168.0.1 - Preferred DNS 194.168.4.100 - Alternate DNS 194.168.8.100
IP camera's address is 192.168.1.65 - subnet mask - 255.255.255.0 - default gateway 1.0.0.0
My Virgin Hub's IP address is 192.168.0.1
I have the Default Route set as WLAN0
I can access the DVR wirelessly with my laptop if I type the WLAN0 address 192.168.0.119 into my browser, I can view the camera stream okay but cannot access the camera itself.
Hik-Connect works okay from my mobile phone and so does iVMS-4200 from my laptop.
I'm assuming it's possible to access the camera with this DVR and Wi-Fi dongle set-up as I can't see any point in making the DVR wi-fi enabled if it isn't.
Sean
Sean
