Setting the time
Bluenose1940
Centurion!
I have a Hikvision NVR DS-7604NI-K1/4P(B) The current firmware is v3.4.99 - Build 171121 which as far as I can tell is the up-to-date version.
Whatever I try I just cannot get the system time to be correct.
I cannot see anywhere that there is an option to set a BST setting and so I have set it at GMT+1 which is the same thing as far as I can see. However, after setting the time it is always showing about 30 minutes in advance of the correct time.
Does anyone have any thoughts on this please?
Thank you so much Phil. Firmware updated and time now in correct sync.
Once again, thanks a million. Very much appreciated.
