A antony23 Member Messages 20 Points 1 Oct 21, 2025 #1 Hi, if i use the onboard relay of the DS-KH6350-WTE1 monitor indoor station, could i use the RFID card/key of DS-KV6113-WPE1(C) (installed at oudoor) to act on the monitor's relay?
trempa92 Knows a LOT of stuff Trusted Member Messages 498 Points 43 Oct 22, 2025 #2 Only way you can trigger output is by calling linkage and Tamper i believe. Card swipe cannot be added to linkage This require custom service to do so
