V Victor New Member Messages 2 Points 3 Nov 17, 2025 #1 I have a DS-7608-NI-E2/8P/ The original cameras are now suffering from IR failure. Would this NVR support the newer IPC cameras. Eg IPC-T280HA- LUF/ SL or would I need to reduce the MP.
Dan Administrator Staff member Messages 4,901 Points 113 Nov 17, 2025 #2 Hi @Victor The DS-7608NI-E2/8P NVR only supports recording up to 6MP, and its last firmware update that added new features dates to pre-2020. So this older NVR model won't support the resolution and advanced features of the latest cameras. To get the most out of upgrading your system, we would recommend upgrading the NVR to the DS-7608NI-M2/8P NVR. If you must keep the older NVR, we would recommend that you use a more basic camera model like the IPC-T240H.
V Victor New Member Messages 2 Points 3 Nov 17, 2025 Thread starter #3 Thanks Dan for your speedy reply, I will look into replacing the NVR
