Hik-Connect New Update
windows700
Acuseek is reserved for /VPRO nvrs and aswell ids 96 series /x
ONce you enable you lose alot of vca for non smart cameras.
It works great. Tested on 96 series
There is video from acuseek on nvr, i havent sen 1 yet on web browser and hik connect
Yeah even without AcuSeek availability, I was hopeful that AcuSearch would work in the new Hik-Connect app for all NVRs/DVRs that support it. I guess that too is also reserved for the higher end NVRs and not the basic NXI models that support AcuSearch. I have a 7604NXI-K1/4P(D) on the bench now with a few AcuSearch compatible cameras. AcuSearch works relatively well in the NVR local UI (first time I've tried it TBH) but there's no change in the new Hik-Connect app.
I received 1 vpro around januray from hikvision for testing. This firmware also adds option to select false alarms and actually learn device which alarms ae not valid. It will not do it anymore, reducing it even lower
It's a shame we don't have the VPro models available in the UK [Yet?]. They are shown on the Hikvision UK website so we can only hope we get them. I'd probably look to replace my DS7616NI-M2/16P with a DS7616NXI-I2/VPro if/when they become available. I don't really need the incoming bandwidth on the M as I'm only running 9 cameras on a 16 channel model. According to Hikvision specs, the DS7616NXI-I2/VPro can run AcuSearch and AcuSeek across all channels if the connected cameras are AcuSense capable.
I2 will be obsolete even in vpro series
It seems strange that it will be obsolete before it is even released in the UK but who knows what will happen. The UK website shows new models that are not available/may not become available here and also lists the DS-76xxNI-I2/xP that has been obsolete for years.
I don't think the I2/VPro will be obsolete, I think they are currently new.
I bought mine in October, I had to wait 2 months for it. Bought on Alibaba.
Maybe it will work in Hik Connect, you just need to switch it to team mode - create team in app, then enable hik connect in nvr and then add nvr via qr code a verification code. It"s pretty difficult. Try this manual: How to Create Hik-Connect Team and Use the Cloud Service - SafeTrolley
Tested on DS-7632NXI-I2/VPro.
That original comment of mine was more regarding AcuSearch in the non Vpro models. AcuSeek and AcuSearch both work fine with the VPro models using the standard version of Hik-Connect; Team mode isn't needed.
Really? Could you please send instructions on how to draw a box around a person in Hik-Connect, then search for that person across all cameras, and also how to enter a prompt in AcuSearch to specify what I want to search for? I wasn’t able to do it in any other way than switching to Team mode. Thanks.
AcuSearch
  • In Hik-Connect click Playback
  • While the target you want to search for is on screen, click the AcuSearch button above the playback timeline
  • App 'scans' the screen and displays boxes around possible targets
  • Click the box that appears around the target you want to search
  • 'I've found the following possible results' appears with a page of thumbnails
  • Click the thumbnail to play
AcuSeek
  • Click the AcuSeek button above the timeline
  • Enter your search term in the box at the top of the page
  • Page with thumbnails appears (with results from all cameras, not just the one that was playing back)
  • Click thumbnail to play
You can't 'enter a prompt in AcuSearch' to specify what you want to search for. AcuSearch is used to select a target on screen and search for similar results (I assume you meant 'AcuSeek')
The only way to use AcuSearch/AcuSeek is to use team mode
It works fine for me and has done on iOS Hik-Connect for months. What exact model number and firmware version is your NVR? Also what version is your Hik-Connect. The ability to use AciSeek on Hik-Connect was added in NVR firmware
DS-7632NXI-I2/VPro, FW: V5.05.361 build 250929, HW version B-R-K22B1_KT5-00.
Hik-Connect on Android, the latest from Google Play - 6.10.970.1210, but today I tried also older versions, for example 6.8.300 and 6.9.880, and same there.
Using cloud is annoying for me, as I have public static IP address.
It should work in 5.05.361 but there is 5.05.365_251029 available. Hik-Connect needs to be latest version (I'm also on 6.10.970 but iOS version) and you'll have to use cloud to get it working. It is annoying that some features are only available with cloud connection to Hik-Connect but that's just the way it is.
