Accessing Plug and Play cameras from my network?
valeyron
Hello,
I have a Hikvision DS-7732NXI-K4/16P NVR.
When I use the included POE ports and first setup the cameras over plug and play it seems to work with an internal IP, but I cannot reach the cameras from local network, and if I change the port to manual and add a camera with a fixed IP the NVR won't see the camera.
For example, when I set up the camera using plug and play the ip is 192.168.251.x but my local network is 192.168.2.x
My question is - how can I manage to make the camera work with a local IP and use the NVR ports?
Or, do I need to leave it as plug and play?
Thanks in advance for you help
Use plug and play with Virtual Host.
Or, add the cameras to your network with LAN IP addresses then add them manually to the NVR.
