Changing Admin password without knowing the old one?
grahamkeen1
Customer has just bought a house with HikVision DS-7208HUHI-K2 fitted. To be able to set it up, we need the current Admin password.
I have used the SADP tool to reset the password using the 'Forgot password' link.
I have exported the XML file, set it to import and created a new password, however when I select 'Confirm' I get the error message "Failed to reset password. Other. 2001"
Any thoughts as to what is going on ?
Graham.
Solution
You cant change it yourself without knowing the old one. What you need is to send that xml to hikvision support and hope they will generate you a reset file. Its not their practice to help end users, but there were exceptions.
Good luck!
Good luck!
Upvote 1
Solution
