Firmware V5.7.17 build 240606
kruja
Hello. I have installed the new firwarmV5.7.17 build 240606 but I have
big problem with the Google SEARCH. The camera is Hikvision DS-2CD3386G2-ISU. It is very slow and difficult to use the camera, through the computer. How can I solve this problem? Thank you.
Hi @kruja
If you remember, can you please confirm what firmware version the camera was running before you updated it to V5.7.17?
Can you also log in to the camera with a browser, go to Configuration > System > System Settings > Basic Information and confirm the "Firmware Version Property" of the camera?
I was using V5.7.2 build 211109.
The camera has updated itself to the new firmware. I happened to notice this and then turned off the camera and restarted it. And now there is a new firmware V5.7.17 build 240606.
Now everything is fine and the browser itself is fixed and the camera works fast and smooth.
I didn't notice this before.
AcuSearch -" After the function is enabled, the ongoing smart application will be disabled while Smart Event or Multi-Target-Type Detection will be enabled. "
Smart supplemental light, when the camera is turned on, it tries to activate something and the image darkens and then brightens again.
