Hikvision NVR Channel No's sorting
Marco Hill
Centurion!
Afternoon,
Does anyone happen to know the best way to sort out the camera devices.
Do I simply go to select the camera and do this under modify.
I am trying to view my cameras in a certain sequence on Hik-connect for everyone that is connected and I believe I have to do this under camera management
and do the above.
Thanks a lot
I hope my question makes sense.
I don't think you can change the order they load in Hik-connect... cameras just load up in the "Channel No." order
I've tried rearranging them in Hik-connect but when you restart the app they revert to the channel number order
@ChrisCCTV thanks. Do you mean in the camera or on the NVR?
@johnfitzy yes I have that exact problem you mention. I messed around with it today again but could not figure it out.
I think one could delete all the cameras and than import them one by one again to get the correct sequence if I am not mistaken.
If Hikvision NVR has a web view you can get the camera action in the size you want and the sequence you want by creating a small client.
Hi Marco,
That screenshot I showed was in the camera's webpage. I don't use an NVR personally so not sure how this works with an NVR.
Hi Marco,
Can you provide one ip of one Hikvision NVR web camera . I would like to view the code and see if it has a transversal path vuln on images and create a client.
I would NOT respond to this request. @Dan is this even a proper request to make?
