D dturtill Well-Known Member Messages 92 Points 8 Nov 15, 2019 #1 Morning Guys does anyone use the Remote Backup software, I am trying to write 30 days of Backups to an external drive and all I keep getting is that it failed writing to disk. I have tried multiple locations and can manually write to all of them
Phil Administrator Staff member Messages 5,195 Points 113 Nov 15, 2019 #2 That's probably a huge file! How are you commencing this? e.g. from a direct-connected monitor? From iVMS-4200? From Internet Explorer?
D dturtill Well-Known Member Messages 92 Points 8 Nov 18, 2019 Thread starter #3 From the Remote Backup software on the same network
Phil Administrator Staff member Messages 5,195 Points 113 Nov 18, 2019 #4 Ah, I've never used it. I've attached the manual in case that helps. Are you running V3.0.0.301? Do you get any error messages? Attachments Hikvision Remote Backup Software User Manual.pdf Hikvision Remote Backup Software User Manual.pdf 482.2 KB · Views: 1,072
D dturtill Well-Known Member Messages 92 Points 8 Nov 18, 2019 Thread starter #5 it just says writing data into the disk Failed
Phil Administrator Staff member Messages 5,195 Points 113 Nov 18, 2019 #6 Have you checked the manual? Are you using the software as per their guidance?
D dturtill Well-Known Member Messages 92 Points 8 Nov 18, 2019 Thread starter #7 yes, the only thing it maybe is that its a network drive. will try on a local
