Door Entry How to set the password to open a door KD8003?
asafalfa
Both DS-KD8003-IME1 and DS-KH9510-WTE1 are connected and operational.
I also have an electric lock that can be opened via the screen; when I press the electric look to open the door, it displays "the door is open" and opens the door.
But I cannot locate the password setting for the keypad.
KD8003's firmware version is V2.2.62 build 230204, and I configure it using iVMS-4200.
Please advise,
Asaf
here you go:
Sure, I do have the KeyPad. (KD-KP)
Thank you for the capture - I did, in fact, set a password and observed two things:
1. When I enter a password and then select Edit, the password is not saved.
2. I've set my password to 121212, but when I input #121212#, nothing happens. I've also tried *#121212#, but nothing happens either time.
I'm attempting to determine what I'm doing incorrectly, as it appears the password is not being stored:/.
Please advise,
Asaf
Also when entering #121212#, do you hear a sound ? It should be 2 beeps (Incorrect code)
i think i use the newest one - V3.9.0.5 Is it right ?
I do hear the sound when i entering each digit but no response in the end as you saying "2 beeps" :/
That version is ok, when entering incorrect code, I hear indeed a beep beep tone...
If your password is not saved, it should be the same beep
No, the password is not stored in the iVMS configuration page (kd8003)
I honestly have no idea why...
I attempted to delete the two public credentials and recreate them in lock1 and lock2, respectively.
I entered 121212...
Returned to the keypad but found nothing:/
Not sure how to identify the problem, any suggestions?
Remarks is saved but not the password
Oh my goodness, I'm thinking about it now!
Each Keypad includes a DIP Switch...
And I do have two intercom-equipped entrances...
Am I correct in assuming that the DIP switch address should not be the same?
Could this possibly be the cause of my problems?
How did u resolve it at the end? I have the same problem, I have 2 DS-KD8003 installed at my home but only one of them is connected with a door. After setting up the password in IVMS, #123456# cannot open the door lock. I assume you had same problem as me initially, so just wondering how did you resolve it at the end? Thank you
Hello , had the same problem. I had all set as should also in IVMs. I fixed it only with one funny thing. I tried first adjusting DIP switch (from default to 1 module) while the keypad module was connected to DS-KD8003 >>> THIS WAS WRONG
So I disconnected the keypad set again DIP and connected back to main camera and it finally STARTED to WORK.
1 Module is:
1 On
3 Off
4 Off
5 Off
6 Off
7 Off
8 Off
This is correct ?
