- Messages
- 4,784
- Points
- 113
Hikvision has released new firmware for their K-Series [76NI-K1(B)] Network Video Recorders. The latest firmware, Version 4.30.000, can be downloaded here.
Below is a summary of all the new features, each is explained in more detail in the release notes.
Reason of Upgrade
New features
2.【Support access in ISUP 5.0 protocol】
5.【Support GUI local online upgrade by Hik-Connect】
6.【Support event recording search in Hik-Connect client】
7.【Support two-way audio function with Hik-Connect】
8.【Add Right-Click menu】
9.【Add online and offline status display of IPC in Web】
10.【Optimization of PoE exception information display】
11.【Adjustment of access mechanism of main stream and sub-stream in Hikvision protocol】
12.【Local playback】
13.【Authority management】
14.【Optimization of storage】
15.【Password of IPC activation equal to NVR password by default】
16.【NVR disable Smart VCA by default】
Modified functions
1.【Optimization of operation】
Fixed issues
1.【Fix the issue that GUI interface exception】
2.【Fix the known defects】
Reason of Upgrade
New features
12.【Local playback】
Modified functions
Fixed issues
