K Kimmy New Member Messages 2 Points 1 Jan 6, 2019 #1 Hi, What is the max cable distance using CAT6 between a 7600 series Hikvison NVR and the camera? I need to install a couple of cameras at a drive way entrance which will be a max run from the NVR of around 130M. Thank you
Dan Administrator Staff member Messages 4,494 Points 113 Jan 7, 2019 #2 Hi, The maximum distance for Cat6 cable in one run is 100m, if you want to go further you will have to use an extender - Veracity OUTREACH Max XT VOR-ORM-XT Outdoor Ethernet and PoE Extender
K Kimmy New Member Messages 2 Points 1 Jan 7, 2019 Thread starter #3 Dan said: Hi, The maximum distance for Cat6 cable in one run is 100m, if you want to go further you will have to use an extender - Veracity OUTREACH Max XT VOR-ORM-XT Outdoor Ethernet and PoE Extender Click to expand... Thank you. In the manual for the NVR it states long distance 100-300M via POE. Is it not a case of turning on extended POE on the NVR?
Dan Administrator Staff member Messages 4,494 Points 113 Jan 7, 2019 #4 Yes, it is possible to reach 300m but you have to use Cat6 and the camera has to be drawing less than 10w of power
